Brokefoot's XSE
10K views 35 replies 14 participants last post by  ccg1018
#1 · (Edited)
Intro: Well... here's my build thread.
Username: brokefoot
Xterra's Nickname: XSE
Year: 2005
Trim: SE
Color: Granite
Transmission: 5 Speed AT
Mileage: 120,114 August 2017, purchased August 2016 w/ 112,554
Modifications (completed):
Armor/Recovery:
_XT Fabrication Front Bumper
_XT Fabrication Rad/Front Skid
_Hefty Fabworks Engine Skid
_Pro-4X T-case, Gas Tank Skid
_P&P Engineering Level II Sliders
_Hardcore Offroad Rear Bumper w/ Tire Carrier (modified by XT Fabrication)
_X-Bull 13K Synthetic Winch
_X-Bull 10T Recovery Tracks
_Hi-Lift Jack
_4.75T Shackles Front/Rear
_Eagle Eyes Black Bezel Headlights
_ARB IPF 968 6.5" Lights
_XT Fabrication Baja style Light Cage
_Offroad Gorilla Hood Struts
_Custom Front Grille w/ 1980's Nissan emblem
_"XSE" Hatch Letters
_Gobi Ladder
_Firestik 4ft Firefly CB Antenna
_Pioneer AVH-x2800BS
_Midland 1001LWX CB
_Suitech Control Box
_Aux/USB Middle Console 12v Flush Mount Port
_ZheKing 6k LED Interior Lights
_Raingler A-Pillar Handles
_StrongArm Lift Gate Struts
_XT Fabrication Prototype Cargo Rack
_Stainless Utili-Track Eye Bolts
_Alcan Springs w/ 450lb extra capacity
_Nisstec Adjustable Shackles
_Bilstein 5125's 3-4in lift spec
_XT Fabrication Rear Bump Stop Extensions
_XT Fabrication Rear Brake Line Extension Bracket
_Nisstec MK84 650lb Coilovers w/ 2in Top Plate Spacer
_SPC UCA's
_Moog LCA's
_Energy Suspension LCA Bump Stops
Wheels/Tires:
_Nitto Ridge Grapplers 295/70R17
_Level 8 MK6 17x8 Matte Bronze
Engine/Exhaust/Drivetrain/Electrical:
_Rad bypass
_Hayden Transmission Cooler (Secondary)
_M226 + R180/Lokka w/ 3.54 Ratio
_ARB M226 Cover
_Offroad Gorilla Rear Diff Breather Kit
_Odyssey Extreme 35-PC1400
_K&N Intake Filter
Modifications (future/wishlist):
_Wet Okole Front/Rear Seat Covers
_Custom Drop-In Roof Basket by XT Fab (in design)
#21 ·
Anything that I sprayed was removed from the truck beforehand (except side moldings). Plastics got hosed with water, then sanded with 400 grit, wiped clean with wax/grease remover and then three to four coats of spray bedliner. Same process for metal parts, with the addition of applying two to three coats primer before bedliner.
Black Bezel Headlights - hope that link works
#24 ·
Well, overhaul is done. The following was swapped and installed on Saturday:
M226 3.54 Ratio w/ ARB Diff Cover
Rear Diff breather
Bilstein 5125s
Ubolt flip kit
Alcan Packs
Brake line bracket extender
Rear bump stop extensions
2 Hard Brake lines replaced
Turned non adjustable extended shackles into adjustable shackles to reduce rear lift because of new Alcans
R180 3.54 Ratio
Replaced 4 bolts/nuts for front cross-member near front diff because UP YOURS NISSAN FACTORY LOCTITE AND MIDWEST RUST
Nisstec MK84 Coilovers w/ Top plate spacer
SPC UCAs
1/4in thick steel Front/Rad Skid
Drives amazing now!
#33 ·
Rear Diff breather
Bilstein 5125s
Ubolt flip kit
Alcan Packs
R180 3.54 Ratio
SPC UCAs
I'm a little late here but did you actually install ALL THAT in one day??
#25 ·
Cleaned the underside of the X this morning. And by "cleaned" I mean painted, because Midwest rust and I'm lazy right now. Yes, I see the overspray on the wheels and elsewhere. Yes I wiped it off with mineral spirits. I'll keep tabs on where I painted about a year from now. Hopefully this slows the aging of my rigs metal. The very least, it looks better than before.
Also, decided against raising front ride height any more. I'm almost exactly at 3.25in over stock, and I want to keep suspension travel and ride comfort just where its at right now. I'm at a 2in rake, but I think once the Alcans settle, I'll be closer to a 1.5in rake which is fine by me.
#35 ·
That's an ambitious list for that timeframe but looking through the list again, I can see why you'd want and have to do it all at once. Kudos on getting all that stuff done.
Still, when it's time for me to swap out my R180 (with a locked R180), I'm going to allocate an entire day for it!
