SyndicateX Build Thread Updated - Project Flexterra 2.0 - Second Generation Nissan Xterra Forums (2005+)
post #1 of 41 (permalink) Old 06-11-2014, 12:46 PM Thread Starter
2011 Night Armor ❌terra Pro-X4
SyndicateX's Avatar
"Photo by: KUMA"
Username: SyndicateX
Year: 2011
Trim: Pro-4X
Color: Night Armor
Front Suspension:
Axle- 2012 Jeep Wrangler JK Dana 30 brake to brake
Teraflex Sleeve, Upper and Lower Gusset Kit
Custom built truss
Eaton E-Locker
Riddler Diff Cover
G/2 4.56 Ring and Pinion
Fox Coilover with remote reservoir
Viper Coil Springs 350/350
4-BDS Adjustable Flex Ends
2-Fat Bob's Garage rubber control arm bushings.
Midnight 4x4 Control Arm Brackets
Midnight 4x4 Shock tabs
Trailgear shock hoops, modified
Driveshaft-Seagull Diesel. Modified and lengthened stock Front driveshaft Double Cardon with 1310 U-joints and conversion flange at pinion.
Xterra extended stainless steel brake lines mount to JK calipers.
Xterra ABS line cut and spliced into the JK ABS line. The Xterra sensor was too long or not enough taper to slide into the hub.
Custom built front cross member
Modified stock transmission cross member
Custom track bar with heim ends
Rough Country Track bar bracket at frame side
Steering:
Jk Tie Rod Knuckle to Knuckle
DOM tube with Heim ends at Pitman to Knuckle
Toyota steering gear box with pitman arm-tapered drilled to fit JK tie rod
Toyota steering shaft and Xterra shaft modified
Frame plated and sleeved to mount steering box
Custom built powersteering hose
Wheel spacers 5 on 5 to 6 on 5.5 Front 2"
Wheel spacers 6 on 4.5 to 6 on 5.5 Rear 1.5"
Rear Suspension:
Stock M226 axle
Spring over axle
BDS Fox Shocks
Tom Woods double cardon driveshaft-redone by Seagull Diesel
ARB Air Locker
Blue Torch Fab Diff cover with high fill
maXTERRA Rear Bumper
maXTERRA Rock Sliders
Xoskel Full Replacement Roof Rack
Aurora 40" light bar via Dark Hour Lighting
Currie Anti Rock Sway Bar: In Progress
From the Beginning:
Stock
2" Body Lift with 285/70R17 Dueller Revo A/T2
2" body lift with Titan Swapped
2" Body lift Titan swapped with Fabtech 6" Frontier kit and spring over axle rear. 315/70R17 Duratrac
Solid Axle Swapped
37/13.50R17 Toyo MTR's, 37's, 37 inch tires
FLEXTERRA 2.0
Reconfigured custom 3-Link
Teraflex Tera44 Front JK Rubicon Axle
5.13 Gears
Eaton E-Locker
Artec Industries Lower Control Arm Frame Brackets
Trail-Gear Joints
G/2 Core 60 Rear JK Axle
5.13 Gears
Eaton E-Locker
Atlas Transfer Case
3.8:1
[URL=http://s1182.photobucket.com/user/SynicateX/media/Solid%20Axle%20Swap/IMG_5375.jpg.html][/URL
Titan Swap-REMOVED, 6" Fabtech Frontier Lift-REMOVED, Spring Over Axle, 4.56 Gears, 37/13.50R17 Toyo MT's. Check, Check.
SAS FINISHED>>>
Last edited by SyndicateX; 05-14-2016 at 10:59 PM. Reason: Tweaked & Added to your Signature
SyndicateX is offline
post #2 of 41 (permalink) Old 06-11-2014, 12:51 PM
2005 Black-n-Silver Xterra S
21SF's Avatar
Sick build
21SF is offline
post #3 of 41 (permalink) Old 06-11-2014, 05:44 PM
2013 Glacier White Xterra Pro-4X 6MT TS'd & 4.56's
Mr_Scott's Avatar
So badass The more and more I think about it, I think I want to forgo the TS and just go all in, SAS....
Mr_Scott is offline
post #4 of 41 (permalink) Old 06-11-2014, 09:48 PM
2007 Solar Yellow Xterra S
Yellow07s's Avatar
Drool! Sweet truck!
Dave
2007 Solar Yellow S 4x4
Yellow07s is offline
post #5 of 41 (permalink) Old 06-11-2014, 09:51 PM
2013 Metallic Blue Xterra S
Fromfrontier2Xterra's Avatar
All I have to say is....wow.
Fromfrontier2Xterra is offline
post #6 of 41 (permalink) Old 06-11-2014, 09:59 PM
2005 Xterra Off Road 4x4 5AT
BullDozerX's Avatar
Well done!
BullDozerX is offline
post #7 of 41 (permalink) Old 06-12-2014, 01:18 AM
2005 Night Armor Xterra Off-Road - Overlanding Build
1. Very nice!
2. After the ABS splicing, do you have lights on the dash? Does the Speedo and 4wd shift motor work? Any codes setting?
3. With all that flex and lift, are you keeping the BL or removing it for a lower COG?
post #8 of 41 (permalink) Old 06-12-2014, 11:40 AM Thread Starter
SyndicateX's Avatar
Definitely drives different. I do miss a lot of aspects of the IFS with Titan swap. With saying that, I would definitely tell you to ask yourself, why are you solid axle swapping. It is worth doing if you are tackling the larger obstacles with the massive amounts of articulation. But then again, the Xterra is highly capable with Titan swap.
SAS FINISHED>>>
post #9 of 41 (permalink) Old 06-12-2014, 11:46 AM Thread Starter
SyndicateX's Avatar
Originally Posted by Surf and Snow View Post
1. Very nice!
I spliced and extended the wires about 8"s to compensate for the flex. No dash lights. Everything is fully functional without having to any other modifications to wiring or sensors. Everything works just as a stock Xterra. I do need to do the VDC bypass because of body roll when going a little fast around onramps and turns which kicks on the slip light. I have to push the VDC button before I start driving. No codes.
If I keep the body lift is with the intent to stuff 37's. Still on the fence. I'll take it off if I can finally decide that I'm staying with 35's. And overcome the thought of having to put in the work to take it off. I was just in Moab week before last with a couple jeep jk's with 4" lifts. I had awesome approach and departure angles at my current height, we would be coming off the same lines and they were just dragging off the ledges. So just weighing out the factors, if can still get 2-4 inches of lift out of my suspension. So maybe take the body lift off and add an inch height to the suspension.
SAS FINISHED>>>
post #10 of 41 (permalink) Old 06-12-2014, 11:52 AM
21SF's Avatar
37's !!!
21SF is offline
