Roof Rack Pipe Diameter / Drain Plug Size - Second Generation Nissan Xterra Forums (2005+)
post #1 of 3 (permalink) Old 05-19-2010, 11:22 AM Thread Starter
2009 Xterra Off-Road
So I know these are totally unrelated, but I didn't feel like starting two threads.
I have a full set of tools back at home, but I'm at college and want to change my oil, but don't have the space/$$ for a full set of wrenches, so I was going to buy a single wrench (if I can find one) for the oil drain plug. Can anyone verify its size? (I know the torque is ~25 ft-lbs)
Also, I believe the roof rack tubing diameter is 2.25" Can anyone verify this? I want some roof clamps, but don't want to spend 50 bones for a fourtreks clamp so I was gonna try these SS puppies from mcmaster (<$8 each), but I want to make sure they'll fit.
Thanks!
Isaac
2009 Xterra OR - black
Tow Package/Tech Package/6 spd
IsaacF is offline
post #2 of 3 (permalink) Old 05-19-2010, 11:49 AM
2009 S
Loki512's Avatar
yes, the roof rack is 2 1/4". as for the oil pan drain. no idea.
the drain for the diffs is a 10mm hex bolt, if that helps most things seem to be 10mm on the X . . .
Making it look easy, since 1980.
Nothing is Foolproof to a sufficiently talented Fool.
Loki512 is offline
post #3 of 3 (permalink) Old 05-19-2010, 09:47 PM
2009 Xterra Off Road
brett's Avatar
14mm wrench on the drain plug. But you'll need a filter wrench, and I like to take off the radiator skid (10mm socket and phillips screw driver).
brett is offline
  Second Generation Nissan Xterra Forums (2005+) > Xterra Tech Topics > Exterior
