Titan Swap Spray Prevention - Second Generation Nissan Xterra Forums (2005+)
 8Likes
post #1 of 34 (permalink) Old 03-18-2017, 12:56 AM Thread Starter
2011 Metallic Green ❌terra PRO-4X
After driving my truck around a couple times after my Titan swap, I am already sick of the amount of mud/water/pine needles that flies off the tires and somehow straight into my front window (I swear it is like I have a funnel on it or something).
I'm thinking I have two options for this - fender flares or mudflaps. I was gonna use generic options for each. Something like these for example:
Flares (pretty sure the truck in a pic is a titan) - http://www.truckcustomizers.com/p-53...xy-flares.aspx
Flaps - https://www.zoro.com/buyers-products...w&gclsrc=aw.ds
Though I'm not sure if the flares will have enough coverage. I also feel like the mudflaps will not prevent the stuff from coming in my window but instead might only protect my lower door.
Anyone with experience with either on a TITAN SWAP or with wheel spacers/offset wheels?
post #2 of 34 (permalink) Old 03-18-2017, 01:02 AM
Dremel Operator
zach_attack's Avatar
Not sure if these will be wide enough for you as they are 2.5", but I used these on my old blazer that had 2" spacers and they worked like a charm.
There's a bunch of different similar styles like this. Mine came with sheet metal screws and install was pretty straight forward. I ended up using a screw about every 1.5" around to ensure smoothness. If the screws are too far apart you get angles instead of a nice curve.
https://www.amazon.com/Pacer-Perform.../dp/B005Y0OT4E
They look nice too. I will be using this when I go wider to stay PA legal. Tread must be inside the flare here.
FYI, nothing is gonna help when you're turning.
: 292
zach_attack is offline
post #3 of 34 (permalink) Old 03-18-2017, 01:37 AM
2011 Super Black ❌terra S Plus
NYTKSHR's Avatar
and this is one of the main reasons I am going to use pathy half shafts with the m205. I want the wheels to stay in the fenders.
NYTKSHR is offline
post #4 of 34 (permalink) Old 03-18-2017, 02:26 AM
2008 Night Armor Xterra SE
bhalverson15's Avatar
I got a set of flaps I was going to put on my dodge... they are huge but could easily be cut down to size... PM me if you want to take a look at them, I traded my dodge in for a new tundra so no use for them now!
bhalverson15 is offline
post #5 of 34 (permalink) Old 03-18-2017, 02:56 AM
2013 Super Black ❌terra X w/Mods
ScurvyX's Avatar
I got a set of these. I just haven't trimmed/mounted them yet. But I'm not swapped yet....
RALLY ARMOR UNIVERSAL FITMENT (NO MOUNTING POINTS OR HARDWARE) BLACK BLACK | eBay
ScurvyX is offline
post #6 of 34 (permalink) Old 03-18-2017, 08:40 AM
2005 Canteen Green Xterra S
Look up Kumas rig, or Pacer fender flares.
mtnbiker49 is offline
post #7 of 34 (permalink) Old 03-18-2017, 09:52 AM
2015 Night Armor Xterra Pro4X 6MT
NachoX's Avatar
Flares (pretty sure the truck in a pic is a titan) - Pacer Flexy Universal Fender Flares
I'm getting ready to put on those flexy flares too. I'll probably just stick em on first, see how they look before screwing them on. I'll post up a pic when I do, in case it helps.
NachoX is offline
post #8 of 34 (permalink) Old 03-18-2017, 11:04 AM
05/6 ❌terra TS/LCKD/4:56/35" Edition & S Model DD for handme downs
ChrisHaynesUSA's Avatar
Move to the desert.
GPD605X likes this.
ChrisHaynesUSA is offline
post #9 of 34 (permalink) Old 03-18-2017, 11:31 AM
Hamman's Avatar
@ChrisHaynesUSA, I can definitely attest to that. My X was always pretty clean just dusty in AZ. Now its, wet dirty pine needles, mud, snow etc... haha. But totally worth it
Specializing in Custom one of a kind motorcycles with men & women's clothing
@droogmoto-Instagram
Hamman is offline
post #10 of 34 (permalink) Old 03-18-2017, 11:33 AM
2006 Night Armor ❌terra S
maXTERRA's Avatar
I've got some of the pacer stuff, but have yet had any time to install it yet. I don't think the front will be too bad, but no way to install them on the rears over the doors.
The front is the biggest issue, getting the windshield and side windows completely covered
Hamman and AlbatrossCafe like this.
"I am concerned for the security of our great Nation; not so much because of any threat from without, but because of the insidious forces working from within."
Douglas MacArthur
maXTERRA is offline
  Second Generation Nissan Xterra Forums (2005+) > Xterra Tech Topics > Exterior
