How-to: 18" Rear Wiper Blade Install - Second Generation Nissan Xterra Forums (2005+)
post #1 of 36 (permalink) Old 02-23-2010, 10:33 PM Thread Starter
2009 S
Loki512's Avatar
Yes, you read that right a full 18 inches! Not some internet prescription scam for enlarging certain parts!
So, as you all know, the stock rear wiper sucks bad. Even the 14" Murano blade sucks.
This is my first car with a rear wiper and I was pretty pissed that the wiper was that bad. So, I set about a long arduous journey to find a cure for the bad wiper blues. After destroying several other blades and an aftermarket Jeep YJ wiper arm (17 bucks into the toilet there), as I was staring at the broken carcass of the Jeep arm, it dawned on me, if I could add a peg to snap the wiper on then I could have any blade I want.
The Jeep YJ arm Fallout:
So, I added the peg . . . tested my 18" passenger blade on it and lo and behold it FITS, the tip of the blade goes right up to the top of the glass with no run over (only the plastic tip of the blade went over). So here it is, the glorious 18" Rear Wiper Blade Mod:
Get a 1.5 inch Machine screw (mine was #8-32), 1 nut to match (again #8-32 here), 2 washers one or 2 sizes bigger (i used 2 #10 washers), 1 washer the same size as the screw (i used a #8), a cap nut to match the screw (once again #8-32), and some blue threadlocker. (you might want to spray paint the parts black to blend in)
Remove the wiper arm(only needed if you want to tighten the spring, see later), the plastic cover over the attachment pops right off, it's a 10mm nut holding the arm to the motor shaft.
So here's how it goes together: Screw/#10 washer placed into the groove that clipped the OEM blade, then another #10 washer and the nut. tighten down good (don't want it to slip out) and threadlock that nut.
Slide new wiper blade over the screw and clip into place (yes, you must have a wiper that can work with the clip models) add #8 washer to the free side of the screw on the top side of the new blade, finally, add the cap nut and threadlock it (don't tighten too much, you want a little rotational movement on the blade so it can sit flush on the window).
To finish, retighten the OEM 10 mm nut to the shaft and replace the cap.
Now stand back and revel in the glory of a fully functional 18" Rear Wiper Blade.
BTW- I bought a Bosch Evolution Beam blade, it has a pretty good bend to it and was too much for the factory spring, so I took a ziptie and zipped up the OEM spring on the wiper arm. this pulled the blade tighter to the glass.
pics on the car, i just figured out how to make the flash work
it looks like it comes off the glass, but the blade only comes off less than 1cm and no contact with paint or other parts of the hatch
Enjoy!
Making it look easy, since 1980.
Nothing is Foolproof to a sufficiently talented Fool.
Loki512 is offline
post #2 of 36 (permalink) Old 02-23-2010, 10:40 PM
05/6 ❌terra TS/LCKD/4:56/35" Edition & S Model DD for handme downs
ChrisHaynesUSA's Avatar
I'm still happy with the Murano blade.
will think about another when this is worn out.
from what I can tell with the Murano there is only maybe 1/2 inch left to clean at the top., more toward the bottom. but Hell who needs the bottom cleaned to see.
ChrisHaynesUSA is offline
post #3 of 36 (permalink) Old 02-23-2010, 10:41 PM
2008 Night Armor Xterra Off-Road
Xorro's Avatar
Nice! I'm gonna' do it too, but I'll wait for your pics.
Also,
... so I took a ziptie and aipped up the OEM spring on the wiper arm.
What is "aipped"? Typo'd "zipped"?
08 OffRoad\
Night Armor AT
Xorro is online now
post #4 of 36 (permalink) Old 02-23-2010, 10:42 PM
2007 Avalanche White Xterra SE, 4 X 4
Chug's Avatar
Mine is getting near the end.. its starting streak.. But Hardly use it.. Its the back window, I use main front window. :-)
take photo's, of this new fancy dandy gadget of yours.
Never give up the high Ground!!
" A man who wouldn't cheat for a poke don't want one bad enough. "
Gus McCrae-
Chug is offline
post #5 of 36 (permalink) Old 02-23-2010, 10:44 PM Thread Starter
2009 S
Loki512's Avatar
yeah, typo i'll fix it later
so, I tried the Murano and had bad results, granted it was a Trico aftermarket and I was tired of it
Also, this became a personal challenge/quest whatever to figure this out. I wanted to be smarter than the wiper SUCCESS!
Loki512 is offline
post #6 of 36 (permalink) Old 02-23-2010, 10:46 PM Thread Starter
2009 S
Loki512's Avatar
I have to use mine, the roads here are nasty with salt that gets blown up in the window and visibility sucks
Loki512 is offline
post #7 of 36 (permalink) Old 02-23-2010, 11:05 PM
usmc xterra's Avatar
Why didn't I think of this? I'm on blade 2 at 63K miles.
Experience is a tough way to learn, because you get the test first...and the lesson afterwards. MC
usmc xterra is offline
post #8 of 36 (permalink) Old 02-23-2010, 11:09 PM
2008 Xterra S
My rear wiper needs to be replaced. I might try this out.
Jeff08X is offline
post #9 of 36 (permalink) Old 02-23-2010, 11:10 PM
2007 Xterra K.H.A.O.S. Edition
Rook's Avatar
NICE! sweet deal Loki! just get some pics up. I am looking to do this....my wiper sucks something fierce and I am looking for a replacement....and as with anything when something goes.....UPGRADE it..don't just replace it nice work!
The Great Ninja of the East
Rook is offline
post #10 of 36 (permalink) Old 02-23-2010, 11:12 PM Thread Starter
2009 S
Loki512's Avatar
thanks! i'll let you know how it works tomorrow and get some pics
Loki512 is offline
