PRG Extensions vs Titan Tie Rods for T-Swap? - Second Generation Nissan Xterra Forums (2005+)
  • 1 Post By kidsixteen
post #1 of 9 (permalink) Old 03-19-2017, 05:28 PM Thread Starter
2009 Night Armor Xterra S 2WD 6MT
kidsixteen's Avatar
I've been searching trying to find an answer here and can't really come up with anything definitive.
Is there any advantage to running TRE's over the Titan OEM parts? OEM is slightly cheaper, but I'm ok with paying the extra money if there's a good reason to do so.
Any insight would be very much appreciated.
kidsixteen is offline
post #2 of 9 (permalink) Old 03-19-2017, 05:36 PM
2011 Metallic Green Xterra PRO-4X
It saves you the hassle of removing the inner tie-rods from the truck. It is kind of a pain to remove the boot and inner-tie rod (you need a special tool which I had to rent at O'reilly and it still didn't fit perfectly).
So basically:
  • the TRE save you a few hours of time but at a slightly higher cost with a slightly weaker result.
  • OEM Tie rods are slightly cheaper and stronger but require 3-4 more hours of effort to install/rent tool
post #3 of 9 (permalink) Old 03-19-2017, 05:43 PM Thread Starter
kidsixteen's Avatar
Wow 3-4 more hours is pretty significant.
Are both options equally good as far as maintaining alignment is concerned?
post #4 of 9 (permalink) Old 03-19-2017, 05:47 PM
That was for me, but I am also a slow worker who had never worked with Tie-rods before. I also counted the time it took for me to drive to the autoparts store to rent the tool. It is probably closer to 1 hour to swap out the inners once you have the tool lol
Both should have very similar alignment adjustability. I just threw mine on haphazardly and the alignment techs didn't have to touch them.
post #5 of 9 (permalink) Old 03-19-2017, 05:52 PM Thread Starter
kidsixteen's Avatar
@AlbatrossCafe thanks for the heads up man.. I'll have to weigh the pros and cons I guess haha.
post #6 of 9 (permalink) Old 03-19-2017, 06:55 PM
2007 Knight Armor Xterra Off Road
Un4seen4's Avatar
Id go with tire rod swap, just easier in my mind along with the fact its one less failure point with the steering, plus then you get a new set of tire rods for the swap too. After doing it once you'll be a pro, i can do a tire rod swap in like 30 min now.
Un4seen4 is offline
post #7 of 9 (permalink) Old 03-19-2017, 06:57 PM
2005 Canteen Green Xterra S
Do it right and just replace the tie rods with Titan ones. I just used a large crescent wrench to replace them. I always believe the more parts you have, the worse your odds are.
mtnbiker49 is online now
post #8 of 9 (permalink) Old 03-19-2017, 11:28 PM Thread Starter
kidsixteen's Avatar
Thanks guys.. just ordered the Titan tie rods. Seems like the right answer.
post #9 of 9 (permalink) Old 03-20-2017, 12:38 PM
2010 Xterra OR
Yea, a large crescent wrench and the tool to unhook the clip is all you need for the inners. They will be a pain the first time though.
bwebb702 is offline
