Door Locks Gone WILD!!!!! - Second Generation Nissan Xterra Forums (2005+)
post #1 of 7 (permalink) Old 04-19-2017, 11:49 PM Thread Starter
2007 Xterra SE
wheeler's Avatar
Late yesterday, I had the Xterra loaded up ready to head up north for work. I started it up, closed door and went in house for a minute. I come out, and its running, with doors locked going nuts! They were going from locked to unlock wildly!!!!!!! I couldn't get in and had to call a tow truck to unlock it! Go figure my spare key was in my book bag inside!!!!
I ended up parking it, disconnecting battery and taking my truck to work. SO from what I have read, it seems the door lock relay or actuator is the issue?!
Does this sound correct? Anyone have this issue before???
Thanks for any help!
DT Long Tubes, Full Exhaust with Magnaflow Cats & 12580 Muffler, IMS, SuperChips with 2* timing advance & 91 Octane Tune, Volant 12740, PRG Spacers & Shackles, Hellwig Helper Springs, PRG Poly Motor Mounts, 285 Duratracs
wheeler is offline
post #2 of 7 (permalink) Old 04-20-2017, 12:35 AM
satown210's Avatar
Check for any aftermarket alarm equipment.
satown210 is offline
post #3 of 7 (permalink) Old 04-20-2017, 06:27 AM
I'd suspect water got somewhere it shouldn't and is causing a switch to misfire.
I remember reading about someone having problems with water leaking into the hatch and causing problems. I'd start there and disconnect the wire going to the key lock, then move to the doors if that wasn't the problem.
I'd pull the fuse for the electric locks in the meantime to make the X usable. I'd also get a key cut without a chip that you can hide on the outside of the vehicle that will get you in the door but not start the X.
Good luck!
Longboardr is online now
post #4 of 7 (permalink) Old 04-20-2017, 08:27 AM Thread Starter
2007 Xterra SE
wheeler's Avatar
I can rule out aftermarket equipment, as I've owned it since new.
I did read on the net, something about water. 2hrs before this happened when I was parking X I after I shut it off, a weird loud noise was coming from under the centre dash. Its never made this noise before and I found that odd.
I looked quickly for the door lock fuse, but it wasn't labeled under the dash. Anyone know where to look for that particular fuse????? Oh how I hate electrical issues!! lol
wheeler is offline
post #5 of 7 (permalink) Old 04-20-2017, 08:55 AM
A quick search online says I was probably talking out of my butt about a door lock fuse. I'd had problem in an older vehicle with the lock occasionally locking itself so I pulled the fuse. I didn't see a door lock fuse in a quick search in the fuse box under the hood or the fuse box by the glove compartment.
post #6 of 7 (permalink) Old 04-20-2017, 11:16 PM
2010 OR
Still don't rule out aftermarket electronics added. Even if you bought it new dealers are well known to install aftermarket alarms on everything in the new car lot. Often driven by the insurance company for the dealership giving a price break if they do this to everything in the lot. If you elect to not buy the overpriced upgraded alarm package they "deactivate" it and just leave it in the car. Cheaper to abandon the cheap POS than to pay a tech to pull it out. The electronics are not very robust and act up a few years later.
early 2010 is offline
post #7 of 7 (permalink) Old 04-21-2017, 11:17 AM
Tlrtucker's Avatar
I had an '00 Chrysler 300M that did this for a bit. Turned out the negative cable from the battery to the chassis was badly corroded from the inside out, so it wasn't obvious. Got the cable off and it literally snapped in half and there was only about 10% of the original copper wire left. After I replaced that the door lock problem went away. Somehow the bad ground was causing the door locks to keep locking (mine didn't unlock, only lock).
Probably doesn't apply, but it's something that's fairly easy to check out.
Tlrtucker is offline
