p1273 After Replacing O2 Sensor? - Second Generation Nissan Xterra Forums (2005+)
post #1 of 12 (permalink) Old 02-24-2013, 12:26 AM Thread Starter
2015 Xterra Pro-4X
marty22877's Avatar
Send a message via AIM to marty22877
Has anyone else gotten this code? I just replaced my drivers side pre cat because of p0430 and the code didnt go away, so i replaced the upstream o2sensor with the bosch o2 sensor from rock auto and the p0430 eent away but p1273 started. I reset the ecm with removing the maf sensor and resetting the codes, but p1273 comes back. This time after almost 150 miles. Anybody have any ideas.? Im at my breaking point now.
marty22877 is offline
post #2 of 12 (permalink) Old 02-27-2013, 12:47 PM Thread Starter
2015 Xterra Pro-4X
marty22877's Avatar
bump - anyone? I was able to get past inspection, but it seems to come on right around 150miles.
post #3 of 12 (permalink) Old 03-01-2013, 07:50 PM
Rooney's Avatar
Do you have a scanner that has live data stream to watch the up stream sensors ? Thats your best route . You need to watch both banks fuel trims long and short and also o2 voltages . They should be switching from .02-.08 constant . If you have a vack leak on that bank ( lean condition ) the voltage will stay low and the fuel trim will be high . They set lean codes when the fuel trim get up around 20% + . . Also fuel inj pulse will show difference between banks.. these do.have a plastic intake that can and do leak . Best way to check is with scanner and carb cleaner sparying around the intake where it meets the lower itake watching the sensor readings.
CLICK ME>>Rooney's 08 X build<<CLICK ME
-1971 Datsun 510 2dr, 5spd, fully built sr20de+t ,87mm weisco pistons , forged rods, Garrett GT28rs turbo...
Rooney is offline
post #4 of 12 (permalink) Old 03-12-2013, 01:17 PM Thread Starter
2015 Xterra Pro-4X
marty22877's Avatar
ran the scanner and got this:
i posted a new thread asking about tid/cid values. I'm wondering why the new o2 is reading .6v???
post #5 of 12 (permalink) Old 03-12-2013, 01:29 PM Thread Starter
2015 Xterra Pro-4X
marty22877's Avatar
also fuel triim values
post #6 of 12 (permalink) Old 03-12-2013, 10:57 PM
2005 s 4X2 s
xterramex's Avatar
i am no expert in auto electronics.... but my electric guy told me not to buy anything other then nissan o2 sensors... that sometimes japanese cars will not take anything other then oem sensors....
xterramex is offline
post #7 of 12 (permalink) Old 03-12-2013, 11:54 PM
Rooney's Avatar
You have something goin on with that cat on bnk2 compared to bnk1. You can see it switching faster then bnk1 and thats a sign the cat is no good. This is how i like to diag cats by graphing them side by side. What else info does this show ? Injector pulse sec , timing per bank ? Something is going on with that bank..
Rooney is offline
post #8 of 12 (permalink) Old 03-13-2013, 02:05 PM Thread Starter
2015 Xterra Pro-4X
marty22877's Avatar
so looks like i pulled a major brain fart, 1273 is bank 1, not 2, so i replaced bank 1's o2 sensor with the bosch i thought was bad. i reset the values and have driven about 80 miles. no codes so far but here's what my graph looks like now. Also you can only get the timing advance. it's not possible to do it per bank. and no on the injector pulse sec.
here's the graph:
here's the fuel trim:
and here's the original spreadsheet it came from. this was over about 15 min
https://dl.dropbox.com/u/8308297/tra..._12-08-16.xlsx
post #9 of 12 (permalink) Old 03-13-2013, 03:16 PM Thread Starter
2015 Xterra Pro-4X
marty22877's Avatar
also, if i hit the accelerator the bank 1 o2 sensors respond
fuel trim:
post #10 of 12 (permalink) Old 03-13-2013, 03:19 PM
akajester's Avatar
Someone else on here had issues with Bosch O2 sensors. If you google it you'll see others having issues with these in their nissans. The Bosch sensors read slower than the OEM ones and that causes all sorts of weird issues. You have to use Denso O2 sensors.
akajester is offline
