How-to: Change the Thermostat - Page 2 - Second Generation Nissan Xterra Forums (2005+)
post #11 of 24 (permalink) Old 12-03-2012, 12:54 PM
Snowtrout's Avatar
Originally Posted by masscomguru View Post
how does the computer know the thermostat is out? what was the code? I have never heard of that...
Since it does not appear this question was answered. In the generic OBDII codes (P0--- not P1---) there are at least 2 thermostat under temperature codes. Pretty much it means that the engine is taking too long to reach operating temperature or it never actually makes it to temp. Slight chance it could be a sensor or wiring issue but the bulk of the time it means that the thermostat is failed/failing.
Snowtrout is offline
post #12 of 24 (permalink) Old 12-03-2012, 05:00 PM Thread Starter
2005 Polar Bear White Xterra SE
Polar Bear's Avatar
Sweet man, glad that helped!! /
Polar Bear is offline
post #13 of 24 (permalink) Old 12-03-2012, 10:07 PM
2006 T-Swap Lightning Silver Xterra OR 4x4
AZ-Ted's Avatar
P0128 is a code for low coolant temperature. Many times this code will come on due to a faulty thermostat.
AZ-Ted is offline
post #14 of 24 (permalink) Old 12-09-2012, 08:07 PM
2007 Lightning Silver Xterra S 4x4 "BaseCamp" Edition
silverflash's Avatar
as I don't have this code yet, but seem to be running a few degrees colder than i used to and it's taking longer to heat up, I will wait till after december 21st, just in case i screw the job up. Need my "get out of dodge and to the mountains" vehicle ready just in case!
OEM fog lights, Nissan Bug Deflector, Nissan Seat covers, Trident white a/c unit mod
Rear Timbrens, Flexible mudflaps, GY DuraTrac 265/75R16 C-rated, bil 5100 shocks front/rear, K&N 57-6014 FIPK, Flowmaster 40/custom y-pipe, vistapro radiator, bully dog GT
silverflash is offline
post #15 of 24 (permalink) Old 12-10-2012, 03:40 PM
any issues when tightening or removing the 3 bolts that hold the t-stat on? Did you use a torque wrench and if you didn't is there room for one? i like to snug things down well but am heavy handed it seems and i think tighter is better when it's not and can break!
post #16 of 24 (permalink) Old 12-11-2012, 01:30 AM Thread Starter
Polar Bear's Avatar
Good questions. As per our PM convo: I wasn't able to find anything on the torque specs for the bolts so I jst tightened them until I felt comfortable (not to break). Jst by feel, taking into consideration how tight they were when you unbolted them. I know it's hard to measure... But that's how I did it and it hasn't given me problems. I only used the gasket... From what I read/was told by the Nissan techs that's all you needed. Also, I didn't use a funnel. I did put a towel around the radiator so it wouldn't make a mess. This is important so you don't get the fluid all over the place (especially careful to not get any on your belts).
post #17 of 24 (permalink) Old 12-11-2012, 02:15 AM
AZ-Ted's Avatar
My FSM says 80 in-lbs for the thermostat housing bolts. That is not much torque at all.
AZ-Ted is offline
post #18 of 24 (permalink) Old 12-11-2012, 10:03 AM
so my plan is to just finger tighten with socket and fingers then put put 1/4" ratchet on it and tighten bolts while holding the ratchet/socket near the junction of the socket and ratchet head until snug. That way, i should not get too much torque that would break a bolt...right?
post #19 of 24 (permalink) Old 12-12-2012, 04:45 PM Thread Starter
Polar Bear's Avatar
Yup, thats exactly what I did!!
post #20 of 24 (permalink) Old 01-07-2013, 03:18 AM
salley1518's Avatar
I'm having a problem with the hot air inside the car, it never seems to blow hot unless i'm accelerating, even after driving for 20+ mins it still seems to blow cold air unless i'm accelerating from a stop, could this be a bad tstat?
Xterra, because the road to happiness isn't always a road.
salley1518 is offline
