P0301 - Misfire Cylinder #1 (now won't start) - Second Generation Nissan Xterra Forums (2005+)
post #1 of 7 (permalink) Old 06-29-2012, 08:26 PM Thread Starter
2006 T-Swap Lightning Silver Xterra OR 4x4
AZ-Ted's Avatar
Angry P0301 - Misfire Cylinder #1 (now won't start)
Just got the P0301 code on the way home tonight. Truck started to run rough, and the SES was blinking. I'm parking it until morning, as it's 110*F out right now. Hopefully, it's just the plug and/or coil pack.
AZ-Ted is offline
post #2 of 7 (permalink) Old 06-29-2012, 08:35 PM Thread Starter
AZ-Ted's Avatar
Tried to restart it last night, but it would not start.
AZ-Ted is offline
post #3 of 7 (permalink) Old 06-30-2012, 07:08 PM Thread Starter
AZ-Ted's Avatar
This morning, I changed the plugs using the how-to from CF (big thanks to shinermiller):
http://www.clubfrontier.org/forums/f...rontier-40507/
Spark plugs were overdue (I'm at 120K miles), but they didn't look bad - just old and somewhat worn. I was hoping #1 spark plug (passenger's side front plug) was going to be looking really crappy, but it looked like normal wear:
Truck will not start. Too hot out to mess with this now. In the morning, I'm going to spray some starting fluid down the throttle body to see if that will help (maybe a fuel issue is causing the no start condition).
AZ-Ted is offline
post #4 of 7 (permalink) Old 06-30-2012, 08:01 PM
Ted, I would try swapping the coils around to see is a) code changes and b) to see if you can get her to start up. You probably just have a bad coil (cylinder 1)
Free bump for other ideas....
masscomguru is offline
post #5 of 7 (permalink) Old 07-01-2012, 03:38 PM Thread Starter
AZ-Ted's Avatar
Thanks man. I tried the starting fluid. I tried swapping coils. No luck.
The weird thing is the electric fan on the radiator kicks on as soon as I turn the key on (this shouldn't be happening). My fear is that something is wrong with the ECU.
Unfortunately, I'm going to have to give up and have it towed to a repair shop tomorrow.
AZ-Ted is offline
post #6 of 7 (permalink) Old 07-02-2012, 06:52 PM Thread Starter
AZ-Ted's Avatar
No start is due to a bad ECM. Bummer.
AZ-Ted is offline
post #7 of 7 (permalink) Old 07-02-2012, 07:38 PM
2007 Xterra Off-Road 4x4
steve500's Avatar
Send a message via AIM to steve500
Ive seen this a few times on the forums and happened to my 05 Frontier spontaneously.
I still have yet to come down to the cause of this.
Dealer says it was bad ground harnesses on the engine and body that split off from the ground junction connected to the battery.
steve500 is offline
