Purge Valve Issue **UPDATE** - Second Generation Nissan Xterra Forums (2005+)
post #1 of 15 (permalink) Old 04-20-2017, 07:41 AM Thread Starter
I just had a repair shop look into my check engine light. They said it was the purge valve. I told them to replace it. Some moneys and a few hours later I drive it home. Coming into work today and that stupid check engine light comes back on. I know it is the purge valve again just by the way it is idling. Is it worth it for me to try to even get this resolved? If the purge valve was replaced what else could it be?
***Update***
I had the code read and it is P0447. The system is stuck open. The valve is good. What would cause the system to stay open?
cody0707 is offline
post #2 of 15 (permalink) Old 04-20-2017, 09:08 AM
What is the fault code? You don't know anything until the code is pulled.
Brunnie is offline
post #3 of 15 (permalink) Old 04-20-2017, 09:11 AM
2005 Red Brawn Xterra Off Road
Mr. Bills's Avatar
. . . If the purge valve was replaced what else could it be?
A clogged evaporative charcoal canister - the plastic box the purge valve is attached to.
Often these can be "fixed" by blowing out the dust and crud inside with compressed air and running the vent tube to a place where it won't get clogged with dust again.
See these threads: http://www.thenewx.org/forum/15-how-...roblem-$5.html and Evap Can Vent Solenoid.
There is also a Nissan TSB on the subject: http://ww2.justanswer.com/uploads/ba...TB07-058a1.pdf
Robert Bills
KG6LMV
'05 Xterra Off Road; '46 Bantam T3-C Offroad Trailer.
Mr. Bills is offline
post #4 of 15 (permalink) Old 04-20-2017, 09:57 AM
Dremel Operator
zach_attack's Avatar
^^what he said. The canister fills up with crud as does the valve itself.
During 99% of your driving the purge valve is open, allowing pressure exchange with the atmosphere and the gas tank. The charcoal filter prevents harmful VOCs from escaping.
During a drive cycle, the system closes the purge valve and pressurises the system. If the valve is gummed up and won't close it won't build pressure. On the contrary, if the filter is gummed up, the system will build pressure when it isn't supposed to. Both situations will throw the same code
: 292
"Always ballcock shank your shackle"
zach_attack is online now
post #5 of 15 (permalink) Old 04-20-2017, 10:05 AM Thread Starter
Thanks for the help. I'll drop the canister tonight and spray the crap out of it. Kicking myself for not just fixing it myself. The auto shop that I trust must have skipped that step.
cody0707 is offline
post #6 of 15 (permalink) Old 04-20-2017, 10:25 AM
Dremel Operator
Mine threw a code when I was still under warranty. Rather than having them band aid it i cleaned it myself and added the breather. Been code free ever since
Fix it the right way
: 292
post #7 of 15 (permalink) Old 04-22-2017, 02:23 PM
It's your can bro. I put a valve in mine same issue few miles later light came on. God a new can and I'm good now. Drop your spare tire its right there. 10mm bolt. And two lines.
tacticoolmike is offline
post #8 of 15 (permalink) Old Today, 11:45 AM Thread Starter
I had the auto parts store run the code. The code that came back is P0447. So my system is reading that it is stuck open. What could cause the system to stay open?
My simple fix was a piece of electrical tape covering the check engine light. I would still like to fix the issue though.
cody0707 is offline
post #9 of 15 (permalink) Old Today, 12:05 PM
Read this:
How-to: Solve Evap Canister Problem for $5
Get a new solenoid and do this:
IM1RU is offline
post #10 of 15 (permalink) Old Today, 12:11 PM
the 2008 Hybrid Edition
bucksnort's Avatar
What year and miles? My was bad and spitting out gas when I tried to fuel it. Was covered under warranty as it's a known emission related problem
If you're "Feeling the Bern", I'd get checked out for STD's.
bucksnort is offline
