Pathy Front Diff Question ? - Second Generation Nissan Xterra Forums (2005+)
post #1 of 20 (permalink) Old 03-16-2017, 03:02 PM Thread Starter
2013 Super Black ❌terra X w/Mods
ScurvyX's Avatar
Looking at a front axle assembly from a '08 V8 Pathfinder for future titan swap. Will the CVs from the Pathfinder work for the swap or do I need titan (length?)
Thanks in advance.
ScurvyX is offline
post #2 of 20 (permalink) Old 03-16-2017, 03:15 PM
2005 Canteen Green Xterra S
Titan length.
mtnbiker49 is offline
post #3 of 20 (permalink) Old 03-16-2017, 03:23 PM
2005 Solar Yellow Xterra SE Off Road MiniBus
JOSX2's Avatar
v8 pathy shafts are if you want to change the r180 to an m205, but want to retain stock width (xterra-width UCA/LCAs).
Pres, NC State Rep
(Nissan OffRoaders of the SouthEast)
JOSX2 is offline
post #4 of 20 (permalink) Old 03-16-2017, 03:26 PM Thread Starter
ScurvyX's Avatar
Thanks for the confirmation. Yard wants $30 apiece so might as well get them so the M205 doesn't have to sit in the garage with the M226 (replacing C200) while I earn for the rest of the swap parts.
ScurvyX is offline
post #5 of 20 (permalink) Old 03-16-2017, 03:29 PM
JOSX2's Avatar
holy hell that's dirt cheap!
the m205 has different gearing than your C200 does....so...you may not wanna do that if you plan on engaging 4WD before you get the m226 installed
Pres, NC State Rep
JOSX2 is offline
post #6 of 20 (permalink) Old 03-16-2017, 03:53 PM Thread Starter
ScurvyX's Avatar
Front and rear diff/axles will be swapped at same time to maintain gearing.
$400$ for M205 w/cvs and 1800$ for M226 w/locker switch. Hope I did well....
ScurvyX is offline
post #7 of 20 (permalink) Old 03-16-2017, 03:57 PM
2006 Super Black Xterra SE
RoadKiller2006's Avatar
You did good on the m205 but could have found a lot cheaper on the m226
RoadKiller2006 is offline
post #8 of 20 (permalink) Old 03-16-2017, 04:05 PM
IssacHunter's Avatar
Thanks in advance.
You can use either OEM v8 Path ones or AM ones. By doing so you don't need any Titan UCA/CO/LCA
IssacHunter is offline
post #9 of 20 (permalink) Old 03-16-2017, 04:16 PM Thread Starter
ScurvyX's Avatar
I've bought the M205, picking up this afternoon, but not the M226 yet. Saw some cheaper ones, but was advised (Rugged Rocks) to stay away from <2008. Saw a couple of those in the ~1100$ range.
If anybody's got a lead on a M226, I'm all ears.
ScurvyX is offline
post #10 of 20 (permalink) Old 03-16-2017, 04:28 PM
JOSX2's Avatar
scope out car-parts.com for the m226. You wanna search for the "Rear Axle Assy (RWD)". Don't email the yards that pop up in the results....call them. You were advised correct to stay away from <2008...2008+ have 4 spider gears. 2005-07 have 2.
I got my locked m226 off a 2015 Pro-4X with 22K miles for $1080 shipped.
you paying $1800...is just plain ol' butthurt!
Pres, NC State Rep
JOSX2 is offline
