Engine Cuts Off While Driving - Page 2 - Second Generation Nissan Xterra Forums (2005+)
post #11 of 35 (permalink) Old 12-26-2009, 02:22 PM
2005 Xterra S
I'm having the same problem with my 05 Xterra. Did the replacement of the sensor fix your problem? I am going to try and clean the connectors before I spend the money. Just wanted to see if they fixed your problem.
scubajohn83 is offline
post #12 of 35 (permalink) Old 12-27-2009, 04:00 AM
2005 s 4X2 s
xterramex's Avatar
how many miles on your truck?
xterramex is offline
post #13 of 35 (permalink) Old 12-27-2009, 01:45 PM
2005 Xterra S
68000
post #14 of 35 (permalink) Old 01-17-2010, 03:39 PM
matts11's Avatar
we have a 05 X and the same thing happen to us, yesterday. except we were turning at a light and the engine just shut down. VDC and SLIP lights came on. scared the crap out of the wife. thank god i was driving. Cranked engine about 3 times and finally it came back to life. the X sat all night, this morning took it for a drive 10 minutes later. engine shuts down and light are back. we are also dealing with the P0463 code problem. taking to our local shop to help out ( not the dealer). will keep you updated on whats up. thanks for all the post and help.
matts11 is offline
post #15 of 35 (permalink) Old 01-17-2010, 10:25 PM
2005 Xterra S
This just happened to me tonite. sitting in a parking lot while idling, it just stopped. got the "service engine soon", "VDC", "slip" lights. it restarted on the 6th or 7th try and then i drove home. it felt normal and strong on the way home.
102k miles with absolutely no problems so far. will a place like autozone be able to pull the codes or do i need to go to dealer?
carfiguy is offline
post #16 of 35 (permalink) Old 01-19-2010, 09:04 PM
matts11's Avatar
so i got some info on my 05 X with 70K miles and the problems we were having. first lets talk about PO463: called nissan and filled a complaint about the fuel level sensor. they basically told me touch luck. the sdealer wanted a $100 to read the code and $450 to replace the fuel level sensor. i told them to kiss my ass, and went right to my local shop. they charged me $250 to replace it. DONE!
now for the engine shutting down with the VDC and SLIP lights coming on: that is a bad cam position sensor on passenger side $150 to be replaced. the shop i go to has a guy working for them that worked at nissan for 20 some years. he said the cam position sensor is a common problem on nissan cars. so for about $400 and some change, we have the X back in one day. i hope this helps anyone out there that was having the same problems as us.
matts11 is offline
post #17 of 35 (permalink) Old 04-11-2010, 11:43 AM
2005 Xterra SE
RGJones's Avatar
Spam? Pretty sure it is. Very off topic.
RGJones is offline
post #18 of 35 (permalink) Old 08-25-2010, 06:22 PM
2005 xterra S 4x4
Hinsx's Avatar
This just happened to me. I was driving and the X died on me. It cranked right back up pulled it into the driveway then died almost right away after I parked. It must be one of these sensors. My truck is a 2005 with about 85,000 miles on it. Going to local shop tommorow.. we see what happens... also my fuel level sensor is broken.. Got to get that fixed too.
PRG advanced coilover kit setup with shackles, shrockworks bumper and XRC-10 winch, 33 inch toyo mts, black granite alloy wheel, Gibson exhaust, Volant intake, Nismo Headers, and airaid throttle body spacer, 2 Diamond 12" D6 subs powered by Hifonics 1600 watt amp, 4 kc lights on roof, high lift jack, and Cobra Cb with firestick antenna
Hinsx is offline
post #19 of 35 (permalink) Old 08-26-2010, 08:18 PM
2010 Xterra Off-Road
This happened to me at about 2,500 miles.
PaulC is offline
post #20 of 35 (permalink) Old 11-23-2011, 10:07 AM
GhostX's Avatar
I am having this problem at 150,000 miles, but the issue is hard starting, no performance issues. Replaced all three cats about 6 months ago.
GhostX is online now
