in
this forum
in
the entire site
Advanced Search
Cancel
Login / Join
What's New
Forum Listing
Showcase
Gallery
Advanced Search
Members
FAQ
Dark Mode
Light Mode
menu
Log in
Sign up
Home
Forums
Xterra Tech Topics
Powertrain & Driveline
Follow Forum
Create Thread
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
Filters
Show:
Loading…
1
1 of 270
Go to page
Go
270
Sticky
SMOD Hit List - Year, Mileage, User and Outcome
iamamused
Mar 14, 2013
18
19
20
392
247K
Mar 17, 2024
by
ptrmorton
Sticky
List of Calsonic Radiator Part Numbers Associated with SMOD
Mr. Bills
Nov 19, 2016
15
53K
Feb 2, 2024
by
Mr. Bills
Sticky
Coolant and Transmission Temps - INFO Dump
Matsayz
Feb 9, 2012
2
3
4
63
50K
Sep 26, 2023
by
khatibrifath
M
Sticky
*** PLEASE READ *** ~ Front Diff Failures
Muzikman
Nov 7, 2007
Poll
13
14
15
287
117K
Jun 26, 2023
by
Lomofo11
Sticky
Want a Little More Power from Your X? Start Here
iamamused
Apr 9, 2014
2
34
68K
Jul 22, 2022
by
smj999smj
G
Sticky
Throttle Bottle Idle Air Re-learn
ghosttownexplorer
Jan 1, 2009
4
5
6
112
158K
Apr 7, 2022
by
westslope
Sticky
Thoughts and Observations on Engine and Auto Trans Cooling
jeff_redx
Aug 19, 2013
2
3
4
65
44K
Mar 22, 2021
by
BDK1234
C
Sticky
Timing Chain Class Action Lawsuit
cjunior125
Sep 30, 2011
12
13
14
261
122K
Jan 9, 2021
by
skimandan
B
Sticky
2005 Hose List for Complete Hose Change Out
biffc
Mar 7, 2019
15
14K
Aug 20, 2019
by
Brazos_bend
Sticky
Radiator/Trans Issues ... Collection of Salient Threads
skibum315
Nov 8, 2010
11
12
13
251
90K
May 7, 2016
by
jsexton
G
Sticky
OBD-II Codes
Glucola
Jan 19, 2011
8
35K
Mar 25, 2016
by
SWBILBY
Sticky
Nissan Engine Codes, Service Bulletins, and Technical Help
LA RANA
Apr 1, 2009
3
17K
Feb 17, 2012
by
LA RANA
K
Sticky
Recommended Fluids and Capacity
kokopop
Jun 21, 2007
Locked
8
243K
Jul 7, 2007
by
brutus_skx
C
Seeking Advice on High-Mileage '06 Xterra - Repair Path for an Old-Timer
cvcstock123
1d ago
16
313
4h ago
by
cvcstock123
Z
Re-gearing Xterra to 3.36 (C200k + M205) - opinions
zstekovic
2d ago
15
288
7h ago
by
gravey
My Road to 4.10s. M205 / M226
87iroc
6d ago
7
388
9h ago
by
gravey
Going the LSD Route
El_Guevara
5d ago
14
522
2d ago
by
gravey
F
More Cam Shaft Sensors Goofiness
fteixeira
Jan 22, 2024
9
542
3d ago
by
ugmw177
Rear Diff Issues
Donnie DeLo
Feb 18, 2024
8
505
3d ago
by
Donnie DeLo
R
Engine Fan Clutch?
rivinius
Nov 3, 2010
2
51
38K
4d ago
by
Dantanna
2008 Xterra S, newer Motor 2010
RayMo21
Nov 1, 2023
9
773
4d ago
by
smj999smj
V
Help Identifying a Transmission Line Name
vdgraaf
Mar 19, 2024
6
287
5d ago
by
SledheadX
W
Heater Core Replacement Advice?
wrXterra
Mar 4, 2024
38
1K
5d ago
by
smj999smj
W
2010 Xterra Overheating following Radiator Flush & New Thermostat
WClark47
Mar 12, 2024
10
592
5d ago
by
El_Guevara
N
Is there a Manual Transmission Reverse Lockout?
Nissan_crawler
Mar 21, 2024
2
227
7d ago
by
Nissan_crawler
Replacement Cat Converter Choice Tracking Feedback / Discussion, (re: P0420, P0430)
Surf and Snow
Oct 15, 2016
Poll
8
9
10
385
130K
7d ago
by
piedmontx
A
4WD Error Blinking when Switching to 4Hi
anasadwan
Feb 21, 2024
2
314
Mar 21, 2024
by
anasadwan
E
Help with Transmission Cooler Lines
Elcid
Mar 20, 2024
4
199
Mar 20, 2024
by
Elcid
Video: Remove entire Dash as one Piece to replace Heater Core? What?!
JeffInDFW
Mar 13, 2024
7
525
Mar 20, 2024
by
eighty
Transmission line Connections / Flow Direction?
NaboCRB
Dec 15, 2023
3
308
Mar 20, 2024
by
Elcid
W
Missing Oil
Whacked
Mar 12, 2024
11
545
Mar 20, 2024
by
Todericus
Catalyst Replacement Prep
87iroc
Jan 8, 2024
40
2K
Mar 20, 2024
by
bizutch
9
P0011 Code
99728
May 1, 2019
11
7K
Mar 20, 2024
by
GreyDuck
B
Long Cranking x 1, Then next day Rotten Egg Smell
Bob-Loblaw
Mar 20, 2024
2
214
Mar 20, 2024
by
ugmw177
S
P0011 Error with Vibration at Speed after replacing Camshaft Position Sensor
ShoutingThomas
Apr 29, 2019
2
1K
Mar 20, 2024
by
phenre
F
Vk56 Swap and u1000 / u1001
fatborry
Mar 19, 2024
2
176
Mar 20, 2024
by
Oroterra
RD196 + RD180 + 3.69 Regear: Can it be Done?
dignoe
Mar 7, 2024
6
320
Mar 19, 2024
by
early 2010
M205 Backlash Bearing
TOB4X4
Mar 8, 2024
5
315
Mar 19, 2024
by
Mark T.
Got P0430 Code for 2 Weeks now Code has been Gone for a 3-4 Weeks now should I still Replace the Cat?
Eastgucci
Dec 21, 2023
22
971
Mar 18, 2024
by
Eastgucci
***Update Now hidden Vac Leak or Slightly Clogged new Cat?? Rough Idle / Random Misfire...
Claytron
Jul 23, 2023
13
2K
Mar 18, 2024
by
h8zgray
V
Oxygen Sensor Data - Help
vdgraaf
Mar 9, 2024
10
300
Mar 18, 2024
by
vdgraaf
Drive Shaft Noise - What's the Culprit?
BRATCAT
Mar 11, 2024
5
333
Mar 18, 2024
by
OpsAdm.in
Engine Appearance Cover
ZoomZ
Sep 17, 2018
21
7K
Mar 18, 2024
by
Smyrnagc
L
Clutch replace 2005 6MT 4X4 - Help
Lugetron
Mar 9, 2024
9
564
Mar 17, 2024
by
Lugetron
Mysterious Coolant leak or Bad Head Gasket?
EMT760
Feb 20, 2021
20
9K
Mar 17, 2024
by
xterramex
B
Simultaneous P0420 / P0430 - Troubleshooting Ideas?
bnjmndsmth
Jan 7, 2024
10
963
Mar 17, 2024
by
xterramex
K
VQ40DE Nissan V6 4.0 Compatibility over the Years??
kylejoe
Feb 9, 2017
5
13K
Mar 16, 2024
by
Errol Curtis
Programmer for Regearing
87iroc
Mar 15, 2024
6
248
Mar 16, 2024
by
JeffPro4x
1
1 of 270
Go to page
Go
270
130.6K
posts
44.5M
views
Discuss anything dealing with Engine, Trans, T-Case, Axles, Diffs, etc.
Show Less
Join Community
Grow Your Business
Forum Staff
View All
dezurtrat
Super Moderator
mtdewmike
Super Moderator
CAchief
Administrator
Top Contributors this Month
View All
El_Guevara
W
wrXterra
87iroc
Recommended Communities
AVS Forum
1M+ members
SkyscraperCity
880K+ members
Deals Forum
40+ members
Home
Forums
Xterra Tech Topics
